Unless something untoward happens, I'll be singing the praises of Pertronix for quite a while. The installation of that simple system literally woke-up my Z. Way-easier starting, revs to 7K without a hitch. I'm one VERY satisfied customer!
My first experience with Pertronix w/1.5 coil was not a good one - my second install with a 3.0 ohmn coil is great - hot coil and no issues at all.
FWIW - I too have had problems with the Pertronix, including both the infamous problem above 4000 RPM, and also a complete failure of a 3.0Ω Pertronix coil.
But in the interest of full disclosure - I also had similar high RPM problems with a ZX dizzy, too.
I'll get someone to look into to tuning the carbs and check on the EI.
What is the reason for not wanting to sync the carbs yourself? Once the technique is understood it is a very simple procedure - even enjoyable. The DVD that Z-Therapy sells is an excellent self study course. I've been successfully tuning SU's since '84 and I still learned a lot from that DVD.
Here are two things I know to be true; 1) most mechanics do not know how (or do not take the time) to properly sync twin CV side-draft carbs, and 2) no one will take the time to get them right except for the person that has to drive the car.
With a review or two of the DVD and the hundreds of helpful hands here, you are assured success.
Some other food for thought - I always see posts about problems with various electronic ignitions, but not so much on the tractor-tech breaker point ignition. They simply work well because they are...well...simple.
Edited by Gary in NJ
