The real question is not about color but about amperage rating. Is 0.3 mm ^2 a typo also (the size of the "brown" link used for the headlight and other circuits)? Would the headlights draw more amps than the fuel injection harness - green 0.5 mm^2 link?
Courtesy Nissan sells a red fusible link that is 0.3 mm^2 in size, which would be a lower amperage rating than the green link. But the altlanticz page says that red is a larger size and higher amperage rating (0.69 mm^2 - 50 amps) than green (0.5 mm^2 - 40 amps).
The Datsun store doesn't tell the size or the amp rating of their red link.
As I said, it probably matters little in function. I'm just trying to understand where the idea came from, that those red (or Br) links should be replaced with 50 amp maxi-fuses or similar.
