  • 6 months later...
I don't drive mine in the rain because some meathead shaved the drip rails and my knees get wet.
I have a similar issue, and water drips from under my dash on my legs and on my ecu, where are the driprails?
The driprails are on each side of the roof, right over the doors.
  • 8 months later...
Ok guys.. Just finished this set up without any real problems.... Did everything as the thread says but my wipers are parking in the up position.... I rechecked the wiring (it's as the thread says) ... It works great but I want it to park down... Any ideas?!
you put the bracket onto the motor 180 out. so undo the bracket, turn it 180 degrees and rebolt it to the motor. done
Bracket as in the peice the connects the wiper linkage to the motor shaft. so just turn it around.
Edited by Zs-ondabrain
Tom, I peek in now and then.
Jsnrjock,
You're welcome. I did it twice. Almost had to smack myself for the second time. but I was in a hurry and ended up spending even more time due to having fixed my goof.
DAve
  • Who's Online   1 Member, 0 Anonymous, 1,458 Guests (See full list)
