Since the 79-81 280ZX BMC is almost unobtainium I was wondering what others have done or are thinking about doing?
1. Is there any advantage to using the Wildwood 1" BMC as outlined on the HybridZ forum?
2. Should I wait hoping that supplies will become available again?
3. Is anyone running the Toyota 4 pot front Brake calipers and stock rear drums with the 7/8" stock 240Z BMC?
If so what is the pedal throw Like?
By the way this for a 1973 240Z
Edited by Gully Foyle
Forgot to include some info
https://www.classiczcars.com/topic/39726-79-81-280zx-brake-master-cylinder/
  • 4 weeks later...
Hi Gully. I am having the same prob. I have new Toyota 4x4 calipers ( early, narrow ) and will mount them on stock rotors. I wanted to get the larger bore 15/16 master, but no luck anywhere. ( Black dragon is back ordered too. ) Due to the increase in pedal effort with the larger bore, I was going to try a universal, double diaphragm booster. Around 100.00, and the firewall mounting studs are stock 3 and 3/8s centers. The one prob. with this is that the master cyl. studs are the same 3 and 3/8s. ( Stock being 2 and 1/8 ) Soooo... because of the unobtainable 15/16 ZX master, I am searching around for a 15/16 master with 3 and 3/8s mounting studs, that will work on the 240Z system. ( 1971 HLS 30 - 39379 )
  • Who's Online   1 Member, 0 Anonymous, 1,485 Guests (See full list)
