Site Updates this Weekend ×
Its got a really rough idle.. moving the dizzy does not do Anything to improve it. around 300-700 rpm
Oddly, if i press down on my dizzy cap the idle speeds up quite a bit and sounds decent.. maybe i should replace the cap too?
I nudged one of my injector clips on accident and it came off, it did not change the idle at all, i think my injectors might be bad, or my dropping resistor... which sucks.
I'll have a video up in a few minutes.
edit: video
http://www.youtube.com/watch?v=5n5Vv4dVxI8
Edited by robftw
https://www.classiczcars.com/topic/39817-it-runs-bad/
Check the connections of the wires on the cap and check the condition of the contacts in the cap and the rotor. For the latter two, you're interested in carbon build-up or wear.
Did you ever check your fuel pressure?
You could have multiple problems combining.
https://www.classiczcars.com/topic/39817-it-runs-bad/#findComment-357994
If your maintenance ignition components are old, just replace them. It's not expensive. You need:
NGK B6ES-11 plugs (pretty sure that's the right one)
NGK blue spiral-wound plug wires
cap
rotor
Also inspect your distributor. Does the shaft wobble? Does the breaker plate (what you're looking at when you remove the cap and rotor) turn freely and without binding. If your distributor is bad, you can (sometimes/usually) buy a rebuilt one from your local auto parts store for around $100.
https://www.classiczcars.com/topic/39817-it-runs-bad/#findComment-358040
Here is some more details
Fuel pressure is good, 35-40 psi at idle
The plugs are brand new NGK Part # 3824 {#BR6ES11} Standard .44 gap
The distributor is Brand new, i set the engine to TDC, marked the #1 position on the old distributor and matched the new one to its old location
The cap points are worn - im installing a new one today
The rotor is also kind of corroded (i used emery cloth to clean it off) but im installing a new one today.
Plug wires are brand new, they have been checked for good contact with the plugs / cap
Now here are some symptoms..
When i push down on the cap itself the idle speeds up and sounds normal.
When i mess with the plugs nothing changes
When i move the dizzy nothing happens
I do not have any vacuum leaks
I pulled an injector plug and it did not change the idle speed, so its not running on all cylinders, but when i push down on the cap and pull the injector plug its audible that something is missing. I hope its just a bad cap
https://www.classiczcars.com/topic/39817-it-runs-bad/#findComment-358042
Back in 2008 I was checking out a 74 for sale that wouldn't run. I messed around with it a little bit and eventually found that the current from the coil erroded the plastic on the cap where the coil wires attaches. I got a new cap and new plugs and got the car running. I bought the car, too.
https://www.classiczcars.com/topic/39817-it-runs-bad/#findComment-358059
Sounds like something is wrong with the center contact from the coil on the cap no?
That's what I'm thinking too, which was why I suggested replacing ignition components.
Sometimes the center contact between the cap and the rotor can be bad. For instance there might not be physical contact between the two.
https://www.classiczcars.com/topic/39817-it-runs-bad/#findComment-358073
I got the cap and rotor on and it fired right up, it ran great for a while and then developed the same symptoms again, however my friend came by (who happens to be a master nissan tech..) And after a few wire traces we found a few injectors to be clogged, so i'll be getting some fuel treatment tomorrow and having at it.
I drove it home with no headlights with said friend following me, Open headers as well... All i can say is it was scary / awesome at the same time. I've never had so many people clap and shout at me in a vehicle before.. all the beach goers were loving it.
We traced the headlight wire too, the redstripe white wire is the culprit. Another thing i figured out is that my right turn signal is not turning on either..
Lastly, i have the dreaded clutch slave/master length problem.. i checked everything to make sure they matched up and the clutch refused to disengage completely.. i ended up building a spacer on the lathe to bandaid it for now, it feels like the clutch is slipping a little bit, i need to shorten it.
1 bad bulb in the speedo, and the clock.
Edited by robftw
https://www.classiczcars.com/topic/39817-it-runs-bad/#findComment-358097
Read up on relays for the headlights. Between myself and Dave Irwin, you can find lots of information on the headlight circuit.
As for the turn signal, check to see if it lights up with the hazard switch. That will give you some idea of where the problem is. Just follow the wiring diagrams in the FSM.
https://www.classiczcars.com/topic/39817-it-runs-bad/#findComment-358100
