Cant edit the last post.. I was adjusting the dizzy and found out the group of wires heading to the thermostat (the 4 bullet connectors) made my idle jump up and down.. Anyways, i pulled them out to the side to where it had high idle and left it, the engine ran amazing, i was able to adjust the dizzy, change the idle speed everything. I guess i had a short somewhere over there.
now here comes the kicker, when i went to rev the engine.. well it died and now refuses to start, i REALLY hope its just because i might be out of fuel.. i put 3 gallons in it earlier today for a short drive / testing engine. Maybe i ran out of gas D: I haven't figured out my average MPG yet. ODO says i drove 40 miles.
missed the edit button again.. Anyways i pulled all the injectors and turned if over to check if it was flooded... and LOL.. it started.. I let the gas run out and decided to do some more investigating.
I cleaned up all the injector clips while i was out there, 2 of them were green with corrosion.. its the simple things everyone misses.
Anyways, i was playing around with the thermostat housing wires, i managed to get the car started again with the injectors plugged in, For whatever reason when i tug on the wire to get a faster idle, and then rev the engine it almost stalls every time.. hmm Don't know why it does this, im going to check the EFI bible tomorrow and look into it further.
Anyways, in the end i found the "sweet spot" I got the engine to have a stable rpm of about 850, it revs to 5k+ with no problems. Needless to say i will be getting out my army of zip ties tomorrow to make sure the wires don't ever move again.
NO, NO, NO, NO, NO!
Slight movement is good. It keeps your contacts good. IMO that's why cars usually develop problems just from sitting too long.
Your problem is that your connectors are crusty, crumbly, and corroded, not that you need to jiggle this wire this way and that wire that way. Your only path to salvation is to clean those connectors up -- or replace them if they are beyond redemption. Your Z shall rise again!
NO, NO, NO, NO, NO!
i was poking around again, its not the connectors themselves, it is the wires just after the bullets, one of them has a short ( i cleaned out all the bullets ) so eventually i will repair it but for now im going have it zip tied in a way that it wont short anymore.
If you have a short, at the very LEAST you should wrap the bare wire with electrical tape. The only thing that should be keeping shorts from happening is intact insulation.
FAIW the bullet connectors are the least likely to give you problems. The various Bosch-type connectors (on the injectors, coolant temp sensor, thermotime switch, cold start valve, air regulator, throttle position switch, air flow meter) are more likely to be corroded and deteriorated. If they make or lose contact by your wiggling wires, they're in terrible shape and need cleaning or replacement.
Edited by FastWoman
Took your advice and took apart my extra (cut) wiring harness. I used the better clips of the two, and used the fuel injector hold down clip (they work better)
The car now idles fine and is running well, I just need to adjust the valves.
http://www.youtube.com/watch?v=ugvFMXsU0G4
I'm reading them now, i'll transfer these pages to my laptop.
Also stevej, I got my hazards to work, the right blinker is acting funny.. i took the battery out and used cleaner on the mechanical parts of the turn signal switch (they are gummed up) And eventually got it to turn on, however as it blinks the front and rear right turn signals fade down to nothing, and all i have is the clicking noise inside the car. Do you think its just bad contacts in the steering column switch?
