Just what I said. Broke the hood release cable. I have to go out of town for a few days and don't have time for a broad search. How the heck do you get under the hood to fix this? Taking off the hindges dosen't look like the answer. Ok McGuivers, what flavor bubblegum do I need to fix this mess?
Unfortunately, that topic comes up fairly often. I was lucky that when my hood release cable broke, it was just after the latch released. I did a jury rig fix with some braided cable until I got another proper cable.
Ok I made the tool described in the other threads, but I'm having a heck of a time getting the damn thing open.
Could I get one of you fine people to post a pic of the 73 style latch where the cable connects so I can visualize my target. It would be a great help.
This is on my 73. I added an extra cable IF ever the original failed as I have read about. Hope it helps.
Bonzi Lon
Edited by Bonzi Lon
added info
We, (fire department), carry a rod with a t-handle on the end the rod has a cut down the middle, approximately 1”, on the business end. We, when a cable has melted or is otherwise not working find a way into the cable according to where the cable and or latch is located put the cut over the cable and start turning as the cable tightens it releases the latch. jlp
