Tried to search fo this problem but came up with nothing. When I went to install my new drive shaft ujoint this morning it was loose. What I mean is the cap was spinning in the whole instead of around the splines. I was replacing the ujoint because i noticed the old one doing the same thing.
Does this mean my driveshaft is no good since the old ujoint caps spun in the wholes and bored them out a bit? Or would buying the more expensive spicer brand joints fix the issue? I just grabbed the only ones available at advanced auto fo 10 bucks.
https://www.classiczcars.com/topic/39918-u-joint-doesnt-fit/
The old u-joint bearing cup should not have fallen out when the retaining clip was removed. It should be a very tight press fit and should have been difficult to remove. Your driveshaft yoke may have been messed with or is just worn out. A salvage yard replacement driveshaft might be in order.
Could be the wrong parts.
could be the right parts and depending on exactly how loose you might get away with the Loctite bearing/ bushing setter compound. You will have to take accurate measurements and buy the rite compound for your gap, remember to devide the difference by two, its a circle in a circle.
