i have a 1972 240 z with a 2.6 and a five speed trans in it okay i hope you all can help me so i had the moter running i just did the tune up ie 'spark plugs cap rotter coil weirs full filter air filter' .. everything was running smooth then i put it in reverse got out to the street then i put it in to first them it just died on me .. i have fuel going to the carb's and all but i don't know what hack happened to the z ....... is there a relay fuse or something that i might have blown or something that i am missing can you all let me know what you all might think it is?????..... think you
https://www.classiczcars.com/topic/39939-need-help-my-1972-z-will-not-start/
OK, so no spark after the distributor. Now check to see if there is spark before the distributor:
1. Pull the short HV wire at centre of the distributor.
2. Place the open end of this wire up near one of the 3 bolts on the strut tower. Have the metal contact ~ 1/4" or less from one of the nuts on the strut tower.
3. Crank the car and you should see a spark jump.
Results:
If you have a spark that means ignition (breaker/points and coil) are ok and the problem is most likely distributor cap, rotor, or plug wires
If you do not have a spark then the problem is coil or breaker/points or power to ignition system.
Edited by Blue
Results:
so i did all of that and nothing . and just replast the ballast resistor ...what els can i do ??
ok so i check t all of those wires they are all good ' i toke off the wire harness raping tape all of that is good 'i need to re ripe it anyway's ' there are no kinks split's or barn't wires either' so i detach-et the positive wire to the ballast resistor and tapt it on my tongue to see it there was currant going threw it and there is so i now don't know what els to do
A good way to kill yourself is putting your mouth on ignition parts in your car. I would never ever do that even if the car isnt running. You should always use a cheap multimeter atleast to test for voltage, they are usually pretty cheap now a days and it will pay for itself instead of buying random fixes and wasting your money. You probably got a plug wire mixed up with another one somewhere, make sure your firing order is correct on the distributor to the cylinders.
Edited by 71Nissan240Z
  • Who's Online   1 Member, 0 Anonymous, 1,365 Guests (See full list)
