Talk about politically incorrect!
Tut, if you have difficulty finding a shop, the carbs are really not that hard to tune as long as the throttle shafts don't leak air, and you have a flow measurer. You have an idle speed and mixture on each carb, and then an adjustment on the linkage to synch the carb flow at higher engine speed. It is just a process of going back and forth a few times to get them set up.
