coopdog240 Posted July 3, 2011 Share #13 Posted July 3, 2011 On my car, the power comes fromthe main harness to the blower sub-harness through the three-wire connector. By the way, my dash is from another Series 1, so I don't know the build date (I threw away the serial numbe plate) so it may be that is why the dash harness has the three-wire connector. If the harness was re-engineered to power the blower through the large single red wire, I would have expected that they would have also changed the blower sub-harness to do away with the three-wire connector too??? Why have an extra wire?? Have you ever been able to find the corresponding three-wire connector on the main harness to plug your three-wire on the blower sub-harness into? Link to comment https://www.classiczcars.com/topic/40084-blower-harness-connector/?page=2#findComment-360569 Share on other sites More sharing options...
240260280z Posted October 21, 2011 Share #14 Posted October 21, 2011 Just reading this thread now as I am seeking help with the connections in the area.I believe the orphan connector in the blower harness is for factory AC. My supposition is based on the drawing on page 26 of the 71 FSM document: "S30 Supplement Manual" . On page 27 it mentions that item 54 (L) is power for AC coming from the same harness so I assume that the 3 pin connector is also some sort of control leads for the AC unit or related louvers,etc. Link to comment https://www.classiczcars.com/topic/40084-blower-harness-connector/?page=2#findComment-369832 Share on other sites More sharing options...
philbar73 Posted October 21, 2011 Share #15 Posted October 21, 2011 If I’m not mistaken, in my 73, the heavy red wire connects to a heavy blue wire that is powered by the accessory position on the key switch. This comes from the accessory relay on the 73 and supplies power to the fan. I have a 72 and 73 heater wireing harness and I believe they are the same. Link to comment https://www.classiczcars.com/topic/40084-blower-harness-connector/?page=2#findComment-369869 Share on other sites More sharing options...
