240260280z Posted July 10, 2011 Share #1 Posted July 10, 2011 (edited) I cleaned clear coated aluminum rims today. At first I just used soap, 3 different scrub brushes and a scotchbrite pad. There were dark spots in the "corners" and deep in the wheel where the brake dust would not come off even with the scotchbrite pad (rougher sand cast areas). I had a wheel solution that I forgot about and gave it a try. Wow, it cleaned everything with just a gentle srubbing action after a 30 second soak. I strongly recommended it: Meguiar's Hot Rims All Wheel Cleaner. It works. Edited July 10, 2011 by Blue Link to comment https://www.classiczcars.com/topic/40155-recommended-for-cleaning-clear-coated-rims/ Share on other sites More sharing options...
signal34 Posted July 10, 2011 Share #2 Posted July 10, 2011 Meguiar's Hot Rims has always worked great for me. They also make a different version for chrome wheels that performs just as well. Link to comment https://www.classiczcars.com/topic/40155-recommended-for-cleaning-clear-coated-rims/#findComment-361146 Share on other sites More sharing options...
