Installing KYB struts & Eibach Springs: Reassembly.
I thought I saw somewhere that with lowering springs you didn't need a strut spring compressor. I can't get the strut mount to compress enough to get the lock nut started on the strut shaft.
Also my new strut boots included these new yellow bumpers. I installed them on the new boots as instructed on the strut boot box but didn't recall seeing any sort of bumper or bump stop when I took the suspension all apart last month. Should this be installed? I thought originally I saw a zip tie holding the boot to the spring cap?
I will go get the one I rented from O'Reilly's again to put these on. As far as the bump stop, the new bump stop and boot came with a plastic ring that snaps over the bump stop and then the outside of that plastic ring fit in a groove in the rubber boot. The boot also seems awfully tight inside the coil spring.
Hi Ben' date=' I installed the KYB/Eibach combo on my'73. I did have to use a sring compressor (got it free from Autozone). I put the boots on with a zip tie at the bottom. Hope this helps.
Cheers, Mike[/quote']
You will need a spring compressor to get the top of the struts back into the tower. I found the back struts could be be muscled-in without using the compressors, but not the fronts, even after cutting one coil from the springs to get the car to sit level.
So I got most all my rear chassis parts media blasted and painted. I put most of it back together today: diff, diff mount, mustache bar, "L Brackets", control arms etc etc. Today for the first time I kept looking at those control arms thinking "it looks like I have two lefts or two rights" I had to go back to my before pictures I posted on another thread to look; but it appears from my old photos that the control arm on one side "looks" like it is in upside down,if you put it in the way the other side is the spindle would be way towards the front of the car and vice a versa. I don't have two left or two right control arms do I? I can't imagine the car would have been normal at all like this. I wouldn't think Nissan did this as a cost savings measure because one side of the inner control arm bushing tube is longer than the other.
