cozye Posted July 15, 2011 Share #1 Posted July 15, 2011 On my EFI 280z, I've replaced a leaky cold start valve, all injectors, fuel pressure regulator, and check valve. all hoses are good and I can't find a leak anywhere.However, it takes about 6 hours for my fuel pressure to leak down and I still can't get rid of my "hot start" vapor lock issue. The car will start, but air in the fuel lines and missing on a few cylinders for a few minutes until it all smooths out.I'd love to solve this issue, but short of injector fans and dry ice, I'm not sure whats left to do. The car runs at a normal temp, 180-190 or so. A little cooler maybe on the interstate. Stop for 10 minutes on the hot day, and it will be a rough start. Link to comment https://www.classiczcars.com/topic/40207-not-your-typical-hot-start-issue-suggestions-needed/ Share on other sites More sharing options...
LeonV Posted July 15, 2011 Share #2 Posted July 15, 2011 Have you tried cooling down the fuel lines before you attempt a hot start, or when the symptoms show up? Link to comment https://www.classiczcars.com/topic/40207-not-your-typical-hot-start-issue-suggestions-needed/#findComment-361578 Share on other sites More sharing options...
cozye Posted July 15, 2011 Author Share #3 Posted July 15, 2011 Have you tried cooling down the fuel lines before you attempt a hot start, or when the symptoms show up?No. What would you suggest doing that with? By the time a fan would cool them down, it would be cool enough to start anyway. I suppose I could use a block of ice.If you let the car sit for 20 minutes with the hood open, it's fine. Link to comment https://www.classiczcars.com/topic/40207-not-your-typical-hot-start-issue-suggestions-needed/#findComment-361590 Share on other sites More sharing options...
cozye Posted July 15, 2011 Author Share #4 Posted July 15, 2011 I think the issue could be solved if I found the source of leaking fuel pressure, but since I've replaced every source of leaking fuel I can think of, I'm out of ideas. Link to comment https://www.classiczcars.com/topic/40207-not-your-typical-hot-start-issue-suggestions-needed/#findComment-361591 Share on other sites More sharing options...
LeonV Posted July 15, 2011 Share #5 Posted July 15, 2011 Spray cool water on the metal lines from a bottle. If it helps, the lines need insulation or some sort of heat shielding. Nissan installed a cooling fan on the 280ZX to alleviate this problem. Link to comment https://www.classiczcars.com/topic/40207-not-your-typical-hot-start-issue-suggestions-needed/#findComment-361593 Share on other sites More sharing options...
buysell Posted July 15, 2011 Share #6 Posted July 15, 2011 Just a SWAG, how old is the fuel pump? It may be leaking back to the tank. Also, are there any heat shields missing/damaged?--Justin Link to comment https://www.classiczcars.com/topic/40207-not-your-typical-hot-start-issue-suggestions-needed/#findComment-361596 Share on other sites More sharing options...
five&dime Posted July 15, 2011 Share #7 Posted July 15, 2011 Does that car have an O2 sensor? I would check that as it takes a while for the O2 sensor to warm up. Link to comment https://www.classiczcars.com/topic/40207-not-your-typical-hot-start-issue-suggestions-needed/#findComment-361597 Share on other sites More sharing options...
Zed Head Posted July 15, 2011 Share #8 Posted July 15, 2011 When I got new injectors my hot start problem went away. But it came back months later a few times after some long drives in the summer. Then, after replacing my FPR with an Aeromotive unit (because my stock one went bad), it has gone away for good, I think because the Aeromotive FPRs leak down rapidly. The downside is that if I don't prime the fuel lines with a switch on my fuel pump circuit, it takes a lot longer to start, especially when cold. Aeromotive says that the leak-down is part of the high-flow design, but I think that it's a flaw.I bought the relatively inexpensive BWD injectors. I think that they sealed well when new but probably leak occasionally when hot, after they got some wear and heat. With the Aeromotive FPR that doesn't hold pressure without flow, no more leaking injectors, no more hot start problem. But every start requires a prime. I will probably go with more expensive injectors and a better FPR in the future now that I know what know.I'm not suggesting buying an FPR that doesn't hold pressure, just adding some perspective. I would guess that new factory injectors probably won't leak like the aftermarket ones do. Or maybe a better, modern injector design. My 95 Pathfinder doesn't leak down, even after weeks of sitting, and it has 200,000+ miles on original injectors.If you wanted to experiment, you might put some sort of manual bypass valve around the FPR to the return line and depressurize the lines immediately to see if leaky injectors is the source of the problem. Link to comment https://www.classiczcars.com/topic/40207-not-your-typical-hot-start-issue-suggestions-needed/#findComment-361598 Share on other sites More sharing options...
cozye Posted July 15, 2011 Author Share #9 Posted July 15, 2011 Just a SWAG, how old is the fuel pump? It may be leaking back to the tank. Also, are there any heat shields missing/damaged?--JustinIt's the original fuel pump, however the check valve is new. I just installed it hoping it would fix the problem. The check valve prevents back flow of fuel through the fuel pump, so that rules out the fuel pumpDoes that car have an O2 sensor? I would check that as it takes a while for the O2 sensor to warm up.no o2 sensor. It's a plain old 280z, with regular L-Jet fuel injection. As dumb as box of rocks.When I got new injectors my hot start problem went away. But it came back months later a few times after some long drives in the summer. Then, after replacing my FPR with an Aeromotive unit (because my stock one went bad), it has gone away for good, I think because the Aeromotive FPRs leak down rapidly. The downside is that if I don't prime the fuel lines with a switch on my fuel pump circuit, it takes a lot longer to start, especially when cold. Aeromotive says that the leak-down is part of the high-flow design, but I think that it's a flaw.I bought the relatively inexpensive BWD injectors. I think that they sealed well when new but probably leak occasionally when hot, after they got some wear and heat. With the Aeromotive FPR that doesn't hold pressure without flow, no more leaking injectors, no more hot start problem. But every start requires a prime. I will probably go with more expensive injectors and a better FPR in the future now that I know what know.I'm not suggesting buying an FPR that doesn't hold pressure, just adding some perspective. I would guess that new factory injectors probably won't leak like the aftermarket ones do. Or maybe a better, modern injector design. My 95 Pathfinder doesn't leak down, even after weeks of sitting, and it has 200,000+ miles on original injectors.If you wanted to experiment, you might put some sort of manual bypass valve around the FPR to the return line and depressurize the lines immediately to see if leaky injectors is the source of the problem.Well, that's interesting that yours still doesn't hold pressure. I think you might have missed the first line of my post. I've replaced the injectors with brand new ones, from MSA. The expensive ones. No help. I replaced the cold start valve, it was leaking when hot, not now. I also replaced the fuel pressure regulator, one from rock auto. Don't remember the name. Basically I've replaced the entire fuel system minus the actual rail, and the fuel pump itself.Gas is definitely boiling on the rail. No doubt about it. Where did you get this Aeromotive FPR? Where did you find out about their high flow leak down design ? I could put a mighty vac on the FPR after driving it and relieve the pressure quick. Thats a good idea.I've searched and searched on this topic in the past trying to solve it. The injector replacement and the check valve replacement I just did yesterday was my last hope. I just hadn't had the chance to look into it Link to comment https://www.classiczcars.com/topic/40207-not-your-typical-hot-start-issue-suggestions-needed/#findComment-361621 Share on other sites More sharing options...
Zed Head Posted July 15, 2011 Share #10 Posted July 15, 2011 I did miss the injector comment. I wonder where MSA gets their injectors.I bought my FPR from a local guy on Craigslist, brand new. An Aeromotive 13301 universal adjustable unit.As for the comment about why they leak down, I sent Aeromotive an e-mail about it and Brett Clow of Aeromotive replied back that they knew about it and it had been discussed. He said that they were planning to put a new FAQ on their web page with the following text (plus a little more) - "The stock EFI regulator was engineered with a mandate to hold fuel pressure for 30-minutes after engine shut-down. This is an government regulation with which new car manufacturers must comply. Unfortunately, the mechanism used to hold fuel pressure when the engine is off, has a derogatory affect on a high-flow, adjustable regulator’s ability to create and control fuel pressure when the engine is on. Aeromotive places fuel system performance when the engine is running, particularly running under high load, at the top of the priority board. Anything, such as a checking mechanism in the regulator valve, which compromises fuel flow and pressure control under high-load engine operation, is therefore eliminated. We believe this no-compromise approach to fuel system performance is one of the reasons Aeromotive fuel pressure regulators are universally preferred by enthusiasts and racing professionals alike, around the world."He said they would also add some text to the instructions about the pressure leak-down.I just checked their web page and don't see it yet, even though on the 24th of March, 2011 he said it would be up in a few days. It's one of those things that marketing people would hate so maybe it got quashed, or maybe they're just very busy. Link to comment https://www.classiczcars.com/topic/40207-not-your-typical-hot-start-issue-suggestions-needed/#findComment-361623 Share on other sites More sharing options...
FastWoman Posted July 16, 2011 Share #11 Posted July 16, 2011 Well, since the FPR comes after the injectors and before the return, I can't see how the design of the FPR would in any way impact flow to the injectors. There's no doubt the stock FPR is very tight, and it works very well. I've admittedly never tried an Aeromotive.Eric, I've been having trouble with hot starts lately too -- the same as you describe. Unline on your car, my fuel rail IS insulated, albeit rather minimally (a layer a rubber hose, wrapped in silicone rubber). Also my OEM fuel pump is brand new. Other than that, everything is new except the FPR and cold start valve. I've checked both, and both are functioning correctly. Oh, I have the cheap Standard Ignition injectors, but I have no reason to believe they're acting up. I don't honestly know how long my fuel rail holds pressure, but I'm 99% certain it has adequate pressure for a start after the 10 min or so that it takes for my car to have a rough start. To be clear, I seem to have a miss that results in an abnormally low idle and clears after I take off down the road.BTW, like Zed, I do prime my fuel rail for a few seconds before every start, so it's not that I don't have pressure. I don't know if it's relevant, but if I leave my car sitting overnight, I'll sometimes hear a bubble or two pass through the fuel pump when I prime it. (The whine briefly changes pitch.) However, I have absolutely ZERO problem with a cold start. The engine fires up instantly and idles normally.My own pet theory about the hard starting is that the CTS and air temp sender become heat-soaked, resulting in lean running for a short time. It would be interesting to see if jumpering the TPS connector for full throttle enrichment -- or unplugging the vacuum line to the FPR -- would compensate the rough running on warm restart. If so, it would support my heat-soaked-sensors theory. Link to comment https://www.classiczcars.com/topic/40207-not-your-typical-hot-start-issue-suggestions-needed/#findComment-361649 Share on other sites More sharing options...
240260280z Posted July 16, 2011 Share #12 Posted July 16, 2011 Too bad you could not cobble the cold start valve outlet back to the tank and use it to pre-flow cool fuel through the rail.ORConnect one of these in parallel with your FPR and activate it to flow fuel through the rail Link to comment https://www.classiczcars.com/topic/40207-not-your-typical-hot-start-issue-suggestions-needed/#findComment-361650 Share on other sites More sharing options...
