Tip - there are so many differences between the various years and models of cars, it is always a good idea to note that in some way when posting. Popular methods include noting it in your profile description, putting it in the auto-signature, or having year and model set as a Custom User Title in your profile settings. These methods all work if you only have one Z.
OK. If the turn signal and hazards work, it's not the socket. I suspect a worn, dirty or broken turn signal switch. On a 240Z, the brake light circuit passes through the switch and that is where it is split into left and right.
Edited by Arne
Now I am almost insane.
-Took both TS switches and cleaned all ther contacts and checked all the wires to make sure they are soldered and in place.
--Now I have the passenger brake light working and no driver side brake light!!! LOL The bridge jump is looking better and better.
GI
Arne I think you were right about the TS switch.
-in checking for continuity between wires we pullud a couple connectors off an 2 wires (green and black) were ever so slightly not locked into place. No we have brake lights!!!
-Thanks for all the help.
GI
