Healey Z Posted August 26, 2011 Author Share #13 Posted August 26, 2011 (edited) 5150, Thanks, for the comments. I actually had a guy come to my house and give me a hand with the balancing and mixture settings. I don't have the video, but did buy a syc tool yesterday, so I can walk through the procedure myself. Tomorrow I will try the lifting of the piston and listen to the engine idle. Anyone have the ZTherapy dvd they would like to sell? QUESTION. I suspect the car is running lean. If I lift the piston and it stumbles, do I turn the screw out (meaning looking up at the carbs from the ground, turning clockwise looking) As for the paint. I had a local guy do it. It is base coat, clear coat, cut and polished. His spray booth is junk, but his work fantastic. This is the second project car he has done for me, and won't be the last. You can really see how deep the paint is, as well as see the paint booth in the reflection. He is up in Roseville CA and his pricing is very good. If anyone is in Nor Cal, and wants his info, let me know. Edited August 26, 2011 by Healey Z Link to comment https://www.classiczcars.com/topic/40591-z-powered-healey-painted-and-back-on-the-roadbut-stumbles/?page=2#findComment-364859 Share on other sites More sharing options...
Randalla Posted August 26, 2011 Share #14 Posted August 26, 2011 If the idle speed increases when you lift the pin, the carb is adjusted too rich. If the speed decreases it's too lean. Turn the mixture nut counter clockwise (looking from the top toward the ground) to lean it out, clockwise to richen it up. You want the idle to rise briefly when you lift the pin and then settle back to roughly where the idle was before lifting the pin. Link to comment https://www.classiczcars.com/topic/40591-z-powered-healey-painted-and-back-on-the-roadbut-stumbles/?page=2#findComment-364861 Share on other sites More sharing options...
Healey Z Posted August 26, 2011 Author Share #15 Posted August 26, 2011 Thanks for info. I will be fiddling with the carbs Saturday morning and also looking for a colortune. That looks like a good tool to have in the toolbox. Link to comment https://www.classiczcars.com/topic/40591-z-powered-healey-painted-and-back-on-the-roadbut-stumbles/?page=2#findComment-364893 Share on other sites More sharing options...
Healey Z Posted August 27, 2011 Author Share #16 Posted August 27, 2011 Wow is all I can say. 1 1/2 turns richer on one carb, 1 turn richer on the other and it is a completely different running motor. I'm sure it is not perfect, but it certainly solved the problem to a large extent. I'm still going to see if I can find a colortune for a reasonable price and I should have sync tool by Tuesday and then I will get these guys really dialed in. Link to comment https://www.classiczcars.com/topic/40591-z-powered-healey-painted-and-back-on-the-roadbut-stumbles/?page=2#findComment-364933 Share on other sites More sharing options...
Randalla Posted August 27, 2011 Share #17 Posted August 27, 2011 Excellent! Truly amazing how much better these engines run when really dialed in. Syncing the two carbs will make at least another 20% difference if they are not at least very close now. How many degrees advance are you running? Link to comment https://www.classiczcars.com/topic/40591-z-powered-healey-painted-and-back-on-the-roadbut-stumbles/?page=2#findComment-364941 Share on other sites More sharing options...
Healey Z Posted August 28, 2011 Author Share #18 Posted August 28, 2011 They were syc'd prior to adjusting the mixture, but not checked afterward. I'm running 10 degrees. I drove it a good 50 miles today and had my foot in it a lot of the time. The car scoots pretty good and sounds great. Link to comment https://www.classiczcars.com/topic/40591-z-powered-healey-painted-and-back-on-the-roadbut-stumbles/?page=2#findComment-364972 Share on other sites More sharing options...
Zedyone_kenobi Posted September 1, 2011 Share #19 Posted September 1, 2011 congrats, it is so good to have rolling works of art like your little British beauty gracing our roads! Link to comment https://www.classiczcars.com/topic/40591-z-powered-healey-painted-and-back-on-the-roadbut-stumbles/?page=2#findComment-365251 Share on other sites More sharing options...
5150 will Posted September 2, 2011 Share #20 Posted September 2, 2011 HealeyZ, could you PM me your painters info? I'm gonna paint mine this winter hopefully and I'm gonna start checking out my options. Link to comment https://www.classiczcars.com/topic/40591-z-powered-healey-painted-and-back-on-the-roadbut-stumbles/?page=2#findComment-365279 Share on other sites More sharing options...
