Want to buy - Air cleaner housing for new round-top carbs
Hi,
I bought some ZTherapy carbs and they're on their way. I opted to not get the adapters and use my old air cleaner housing - I want to get the one that matches the carbs. I looked on ebay - nothing today. I found one in datsun classified and emailed the lister, but it was listed in February, so I doubt he still has it.
Anyone out there got a spare I can buy?
Thanks!
Yes, the early ones work fine. biggest problem rounding up an early aircleaner is to find one with all the attacking hardware included.....
The flat tops had a square mouth hence the need for the adapter plates + that air cleaner also looks like it has a growth of some kind on it.
To attach the early air cleaner you need 2 bolts that screw into the carburetor. These bolts receive the wingnut bolt that attached the air cleaner cover to the body of the air cleaner.
The part number for the receiving bolt is: 16517-25600 (2 required).
The part number for the Cover bolt is : 16516-E3210 (2 required)
Dave Ruiz
Anybody have a complete set they can lay out and shoot a pic of for the files here?
Anyone found these at NISSAN? At this late date I'd be surprised if they had them or even knew what we woeld be asking about.
