Believe it or not there aren't that many variances.If memory serves,the FPR keeps the FP 33.5 psi ABOVE manifold vacuum?I'm trying to recall this from the FSM.Once you know where/when the problem is happening,it should point the flying fickled finger of fate at the culprit.
Well with high pressure fuel line @$6.49 a foot I've decided to cram a "little person" politicly correct? under the hood and let one of his little fickle fingers point out the culprit. That was mean but damn that hose is high! A friend of mine rear-ended a car driven by a little person the other day. He asked him if he was ok and he said "well I'm not Happy".
Go ahead..say it:"smidgit".
Yeah,FI hose ain't cheap.What about borrowing some line or borrowing some 4AN hose with fittings just for the test process?
Also little tip:
IF you replace the FPR and that doesn't do it,take it back off and soak it in rubbing alcohol over night.Then let it sit in the sun for a couple hours.THis will get rid of any fuel smell and the store SHOULD let you return it.
Edited by Z train
  • Who's Online   2 Members, 0 Anonymous, 1,446 Guests (See full list)
