Looking for 9mm 240z rods + question about them
I'm building up my stroker engine this winter, i almost have all of the parts gathered up.
The flywheel will be lightened, crank will be lightened & balance, but the thing im not sure about is getting the rods lightened up, could this lead to catastrophic failure? or are they beefy enough that i can take a few grams off them and not have to worry about it?
oh, and the pistons i have will be lightened up a bit too
You can do it but it's knowing how and where to do it which is the important bit. ;)
Can I suggest you get the book "How to modify your Nissan/Datsun OHC engine" by Honsowetz if you haven't already got it. A good read and will answer all your questions in regards to rods, cranks pistons etc.
Or you can search this forum and/or Hybridz. This topic has been covered many times.
Good luck with your project.
  • Who's Online   1 Member, 0 Anonymous, 783 Guests (See full list)
