I'm aware that the order of the wires on the distributor is (counter clockwise) 1,5,3,6,2,4. However, when connecting those wires to the spark plugs does #1 start at the front of the engine? I'm sure it does, but do I follow the sequence 2,3,4,5,6 consecutively in that order when connecting the wires with the plugs? Or is the sequence not so straight forward on the cylinders?
My engine is misfiring after I disconnected the the wires to replace my valve cover gasket. Thanks!
https://www.classiczcars.com/topic/40758-l28-cylinder-order/
It is straightforward: 1-2-3-4-5-6 from front of the engine, 1-5-3-6-2-4 counter-clockwise on distributor.
I had a similar issue after adjusting my valves. Check your plug wires at the plugs (and distributor), they may be loose. I had to slightly crimp one of my plug wire ends so that it would "click" into the plug again. Also, be sure to check the coil-distributor wire.
Also make sure that your distributor cap is seated correctly.
Edited by LeonV
  • Who's Online   2 Members, 0 Anonymous, 598 Guests (See full list)
