1971 240z Licence Plate Lamp Photos
I am posting some photos of part details as I restore. Hopefully they can be of use in the future.
I painted the light compartment white to improve output.
Heat Shield (seems like engineering correction to alleviate melting plastic)
7.5W
Retaining nut in place.
Light leak at top edge. Gasket does not seal.
Edited by Blue
Technical Article Merge
https://www.classiczcars.com/topic/40844-1971-240z-licence-plate-lamp-photos/
  • 3 years later...
Restoring a 73 wiring harness so I started from the back :)
Polished a bulb as an experimnet:
post-6852-0-80861200-1427600793_thumb.jp
post-6852-0-71646600-1427600797_thumb.jp
post-6852-0-69768600-1427600799_thumb.jp
Shined up a heat shield as an experiment:
post-6852-0-58581100-1427600809_thumb.jp
Washed (will remove yellow and paint tomorrow)
post-6852-0-87758500-1427600814_thumb.jp
post-6852-0-11763800-1427600812_thumb.jp
Washed and polishing plastic windows.
Note the inside is black plastic so the outside is painted a metalic grey-ish colour.
post-6852-0-46240500-1427600821_thumb.jp
post-6852-0-07843600-1427600818_thumb.jp
Here is the hardware for reference (1 clip is missing)
post-6852-0-37392800-1427600806_thumb.jp
Gasket
post-6852-0-02820500-1427600802_thumb.jp
Nice picture gallery.  I'm in the middle of the same process, working with a combination of the best parts from 3 separate units.  In all cases, to a greater or lesser extent, the black plastic housing has warped from excessive heat.  I wonder if this design might be a good candidate for LED lighting.  Anyone tried this?
Also, the gaskets in all of my donor units have torn.  Any thoughts on where to source a sheet of 1mm-thick neoprene?
You are lucky to have a few to choose from!
The replacement LED is part 1895.
It has to shine down 90 degrees to the socket axis.
An LED would run cooler and enable removing the metal heat shields.
Fill the socket and connections with dielectric grease.
craft stores such as joanne fabrics or michaels (west coast chains) sell foam sheet with a self-adhesive peel-off backing, used for making stick-on decorations. i've used this material for non-critical sealing and squeak-fixes between interior parts. industrial fabric shops that sell fabrics/supplies for upholstery, outdoor equipment etc. (we have seattle fabrics out here) sell neoprene in many thicknesses.
Thanks for this.
I just finished installing this part.  Fortunately I had two in the shop, because after carefully cleaning and painting the first one, I discovered that the centre mounting hole was waaay to big.  Someone, somewhere in the past 44 years, had apparently tightened the bolt too far, and punched out the hole.
Cleaned up the second one and it seems OK.
  • Who's Online   0 Members, 0 Anonymous, 1,514 Guests (See full list)
