Anyone ever smoothed out a balance tube?
Can't tell where the weld was. Mind you, this is not as clean as the eurotube, but much nicer than stock with all of the smog stuff-I left the threaded ports in and plugged with alan screws. This was a cheaper and easier option than replacing linkages and the balance tube.
Project is officially started. I have 8 stands/ports to do. I got half of them done so far and also found a guy that will let me use his welder, set up to do aluminum for $30/hour.
First pic is the car, second pic is the extra tube I bought, third pic is the extra tube with a few of the features removed.
Edited by Healey Z
dkw,
Thanks for posting, that looks great.
I've completed the prep work for welding, which I hope to do one evening next week. We'll see how my first experience at welding aluminum goes.
Edited by Healey Z
I rented a welder for $30/hour and knocked out the tube. I can't say that it was the cleanest welds in the world, but I am confident that the holes are sealed.
I hope to get it on the car tomorrow.
Edited by Healey Z
This should wrap up this post. The before and after shot. If I were doing it again, I would smooth out the two stands, but leave the bumps in the tube and fill the hole. This would give the balance tube some personality, instead of being so smooth. I guess I'm really never satisfied :) Next is running the gas line under the carbs in metal.
  • Who's Online   1 Member, 0 Anonymous, 1,493 Guests (See full list)
