My shell has 300K miles on it and been painted 4 times. The lines down the sides of the car were vague at best as they had been sanded/dinged multiple times. Kevin Leblanc at Austin Z-Clinic brought them back to life. Lots of hard work went into it. I asked him to make them a bit more pointy than stock... The lines were built up with thick epoxy primer and block sanded (repeat ad nausea). Click the Large View link. Wha-da-ya-think?
Also started spraying Lizard skin underneath. Neat stuff. I brush POR'd the all the non-exterior panels so the Lizard Skin went over the POR after scratching it up with a red scouring pad.
https://www.classiczcars.com/topic/40901-side-panel-lines/
Better yet, go to the auto parts store and buy a roll of that chrome strip with the red rubber center bumper and hand it to the guy that did all the sanding work, and ask him if he can install it to protect the lines. You can return it if he doesn't succeed in shoving it down your throat.
https://www.classiczcars.com/topic/40901-side-panel-lines/#findComment-367527
  • Who's Online   2 Members, 0 Anonymous, 1,493 Guests (See full list)
