Hey I was wondering if having no continuity on the air regulator would be the reason why no power is going to the fuel pump which comes afterwards, also would that affect the injectors also? because they dont fire when I use an external power source on it. the injectors have power, the fuel pump works, the relay clicks, but no continuity on air regulator.
https://www.classiczcars.com/topic/40996-no-continuity-on-air-regulator/
