71 240z resto had bare corroded wires where the fuel sender connectors were supposed to be. Here is the quick and dirty solution:
Step 1:
Pillage the 280z 2+2 wiring harness that I bought from Jim Karst many moons ago (THANKS JIM)
Step 2:
Prepare to solder.
Here are the pillaged parts:
- black wire with bullet connector
- yellow wire with bullet connector
- rubber boots for the solder tails
Step 3:
Solder the leads:
note:
- the yellow lead carries the voltage and attaches to the pin with the elevated stand off (insulator)
- the black lead is the return and is at ground potential. (not insulated and connected to the metal cover)
- when soldering; ensure that the pins are thoroughly scraped/sanded down to exposed shiny brass metal, as well; ensure that sufficient heat is applied to the grounded pin so that the solder flows well and no cold solder joint occurs.
Step 4:
Seal the boots with silicone
Step 5:
Solder a second set of new leads with bullet connectors to the wiring harness:
In this photo, the new leads are on the right and the harness is on the left. I was unable to scavenge a yellow lead so I used a black with yellow tracer stripe.
Step 6:
The wires are now joined and soldered. Note the heat-shrink ready to be positioned.
Step 7:
The completed connections being tested.
note: the bullet connectors at the harness are for the fuel pump.
Step 8:
The harness is now in position. I used the front deck grommet for the fuel leads and the back grommet for the rear ground lead.
Step 9:
The fuel sender leads come through the floor just behind the fuel sender neck.
How the sender works:
1. 12V is applied to a b-imetal switch in the dash's fuel gauge then continues back to the gas tank via the yellow wire.
2. The fuel sender in the tank has a float that rises and falls with fuel level. As the float moves, it also changes the resistance in the circuit to the bi-metal heater.
- The fixed side of the fuel sender's rheostat is connected to the yellow lead and is insulated
- The variable side (wiper) of the fuel sender's rheostat is connected to the black lead and is grounded
- As the float rises, the wiper effectively brings the ground closer to the yellow lead. This decreases the resistance in the bimetal circuit. This inturn causes quicker heating of the bi-metalstrip and pushes the indicator in the gauge towards the full side.
- As the float falls, the wiper travels further from yellow lead. This increases the resistance in the bimetal circuit. This inturn causes slower heating of the bi-metalstrip and does not push the indicator as much thus the the gauge moves towards the empty side.
3. Resistance of fuel sender typically ranges from 10ohm to 80ohm (full/empty)
