siteunseen Posted November 20, 2020 Share #25 Posted November 20, 2020 This really helped me when I was learning the SUs. Thank you @240260280 https://www.classiczcars.com/forums/topic/39221-quick-and-dirty-su-tuning/ 1 Link to comment https://www.classiczcars.com/topic/41017-help-su-carbsof-course-idle-is-at-1800-cant-bring-it-down/?page=3#findComment-610788 Share on other sites More sharing options...
Av8ferg Posted November 24, 2020 Share #26 Posted November 24, 2020 So, as I ponder a possible carb conversion I wanted to begin by educating myself. This guy on YouTube seems to really know about these SU carbs. It might help all interested parties get those carbs tuned right. This video is part 1 of his SU tuning series. Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/topic/41017-help-su-carbsof-course-idle-is-at-1800-cant-bring-it-down/?page=3#findComment-611072 Share on other sites More sharing options...
Mike Posted November 25, 2020 Share #27 Posted November 25, 2020 Before you rip them out and replace with different carbs... you can do a small rebuild yourself. If that isn't in the cards, just send them over to Ztherapy for a rebuild. 1 Link to comment https://www.classiczcars.com/topic/41017-help-su-carbsof-course-idle-is-at-1800-cant-bring-it-down/?page=3#findComment-611083 Share on other sites More sharing options...
siteunseen Posted November 25, 2020 Share #28 Posted November 25, 2020 I think you should find a good rebuild able set, buy the kit from ztherapy.com that comes with the DVD for general instructions. I love videos but the only way for me was the hands on approach. You clean them as you go, make sure and keep the parts separate to the front and rear, wipe them down with this stuff and you'll be happy. BTW, how deep have you already gone with the EFI? That's something to consider in my opinion. That's why I have a set of SUs mounted on the wall in my garage. I replaced my whole EFI system before I bought a 240 and fell in love with the carbs. I'm sure you seen this but I'll post it again. Link to comment https://www.classiczcars.com/topic/41017-help-su-carbsof-course-idle-is-at-1800-cant-bring-it-down/?page=3#findComment-611115 Share on other sites More sharing options...
bartsscooterservice Posted December 6, 2020 Share #29 Posted December 6, 2020 Basically constant vacuum carbs are very easy, but if you are used to downdraft carbs like most US cars use, it can be confusing at first. The screw on the lower part is mixture control. The vacuum controls the fuel delivery. The choke pulls the venturi down ( same like putting the needle up ) and creates a richer mixture. Float bowl level has to be right offcourse and all the parts function correctly. Carbs can be synched by hand and view ( watch throttle valve opening ), but with an air flow synch tool is better and more accurate. Link to comment https://www.classiczcars.com/topic/41017-help-su-carbsof-course-idle-is-at-1800-cant-bring-it-down/?page=3#findComment-611972 Share on other sites More sharing options...
