The plastic trim has a barrel-shaped retaining clip that rusts. This fastens into a speed-nut like clip on the body
Here is the body clip with the retaining clip installed. Both were acid dipped and primed.
On this 240z, there were two different width body clips. One hatch vent used wide and one used narrower.
I seem to have misplaced the photos of the door interior parts of the vent system. Here is one that I have. It shows the plastic part that attaches to the inside of the vent hole. It originally had a foam seal that has long since decayed so I replaced it by gluing on new foam then cutting out the shape.
To install the body clips and not damage the paint, I used a waxy paper to help the clip slide into place.
Note there is also the plastic part underneath that the clip fastens.
Once the clips are in place, the barrel retainers can be inserted.
The clips are in place and top finishing chrome vent is ready to go on
Note the new 2-way tape installed in the centre as well as the epoxied plastic pin that had broken off.
Job done
https://www.classiczcars.com/forums/topic/41029-hatch-vent-trim-installation/
