I am trying to adjust the toe on the front end of my 1971 240Z but I am having no luck loosening the jam nuts that keep the tension between the tie rod ends and the steering rack. I have tried penetrating oil and a propane torch. I can't seem to get either side to budge. I'm pretty sure the driver's side has reverse thread and passenger side is normal. Other than that is there anything I am missing that is keeping me from getting this nut loose?
Here is a picture of my problem nut from the passenger side...
https://www.classiczcars.com/topic/41038-tie-rod-jam-nut-trouble/
You may be turning the jamb nuts the wrong way. Its not hard to become confused when under the car.
The right side has a conventional right hand thread.The left side or your drivers side has a left hand thread.
You may be able to loosen them. Place a heavy block of steel e.g. an axe head or a large hammer behind
the area adjacant to the jamb nut, then give a few good blows with another hammer. Then give the nut a
couple of blows in a similar fashion. Don't hit withought a weight behind the area, as you may do some
damage to the rack.
Edited by olzed
I have used vise-grips on the body of the threaded cast steel and clamped them so that they rotated up against the cross member when I used my very large long-handled adjustable wrench to loosen the nut. I didn't want to put the torque on the ball joint. They can get pretty tight, even when I just give them a firm tighten, they have always been hard to get loose the next time around (I messed around with toe settings for a while, long enough to prematurely wear out a set of tires - zero is a good number).
You're right, one thread is lefty. You can eye-ball it and tell which one, and which way is off.
Supposedly the home-brew acetone/ATF mixture is the best performing stuff, by far. I once saw some controlled test results comparing various penetrating oils and the home-brew stuff thrown in just for laughs.
You might try whacking the end of a long wrench with a big rubber mallet. You can get quite a lot of torque that way.
  • Who's Online   2 Members, 0 Anonymous, 1,538 Guests (See full list)
