Power antenna Area Reference Photos
The antenna on this 71 240z does not seem to be stock.
Here are the parts (in sequence) when removing/installing
The area between the rear quarter panel (fibreglass) and the rear deck:
There is a wingnut and stud which I guess is where the original antenna is attached.
There is also a drain hole for a tube coming out of the antenna (potential fume hole).
Lots of painted ziebart in the bottom too
Here is the tube in place.
I used the wing nut to ground the antenna's ground lead.
https://www.classiczcars.com/topic/41064-power-antenna-area-reference-photos/
I am out numbered by good friends. I must concede. The resto is someone else's cars so I will ask the history (He was original owner so he should know). It was interesting to see the two holes in the yellow pic above. This car has no holes due to body work so I will have to re-drill.
The fact that all pics I googled have only one bracket that goes deep to the wing nut; but the 73 yellow photo above seems like the correct drilling for the holes, I see how it should work but I am confused.
  • Who's Online   0 Members, 0 Anonymous, 1,556 Guests (See full list)
