Stangrage Posted October 21, 2011 Author Share #13 Posted October 21, 2011 I am referring to the terminals on the injector connector itself. Positive going from the Resistors and negative coming from the ECU. I have already tested whether the Dropping resistors are getting voltage and they are. I have also tested the main ground circuit and also all ground circuits to the ECU and all are normal. Ill read over the suggestions again and determine the next course of action. thanks for the suggestions, hopefully tomorrow I will be back with more important info. Link to comment https://www.classiczcars.com/topic/41113-1976-280z-no-start-no-pulse-to-injectors/?page=2#findComment-369795 Share on other sites More sharing options...
Stangrage Posted October 22, 2011 Author Share #14 Posted October 22, 2011 I got my Z running on 5 cylinders, finally! I found a short going to injector #3, I repaired it and then shortly after I found a shorted out injector. Thanks for your input!-Stangrage Link to comment https://www.classiczcars.com/topic/41113-1976-280z-no-start-no-pulse-to-injectors/?page=2#findComment-369925 Share on other sites More sharing options...
FastWoman Posted October 23, 2011 Share #15 Posted October 23, 2011 Cool! Five cylinders are definitely better than none. I wonder whether that 6th injector might be stuck or clogged. You can run some SeaFoam or Chemtool B12 through your tank to work on varnish in the fuel system. Link to comment https://www.classiczcars.com/topic/41113-1976-280z-no-start-no-pulse-to-injectors/?page=2#findComment-369945 Share on other sites More sharing options...
Stangrage Posted October 23, 2011 Author Share #16 Posted October 23, 2011 about 4 months ago when it was last running I soaked them in decarbonizer. I am currently debating on buying new injectors, any suggestions on where i can get inexpensive injectors, ya gotta po-boy here. Link to comment https://www.classiczcars.com/topic/41113-1976-280z-no-start-no-pulse-to-injectors/?page=2#findComment-369988 Share on other sites More sharing options...
Zed Head Posted October 23, 2011 Share #17 Posted October 23, 2011 A walk though the wrecking yard might be worthwhile if there are any Zs or ZXs there. I found a set that looked either factory new or newly rebuilt. Nissan brand. Often, people will replace many parts before giving up and junking a car. You can tell at a glance if the injectors are new, old ones are typically rusty and corroded. Link to comment https://www.classiczcars.com/topic/41113-1976-280z-no-start-no-pulse-to-injectors/?page=2#findComment-369991 Share on other sites More sharing options...
FastWoman Posted October 24, 2011 Share #18 Posted October 24, 2011 Hmmmm... Zed has an interesting thought/observation there!Failing that, I've had luck with the Standard Ignition injectors sold on eBay for about $150 for the set. (I'm a bit "po" myself, so I can sympathize.) Link to comment https://www.classiczcars.com/topic/41113-1976-280z-no-start-no-pulse-to-injectors/?page=2#findComment-370046 Share on other sites More sharing options...
