We have 225/50R15 on 15x7 wheels on our 73 240Z and they fit fine without rubbing. The wheels are 0 offset. Using the 15x8.5 wheel may yield a slightly wider cross-section.
Changing the struts and/or springs will not change the tire fit unless you go to coilovers or section the struts.
