siteunseen Posted October 21, 2011 Share #1 Posted October 21, 2011 (edited) I've found -6 size aluminium fuel rail stock on e-bay for $10 a foot, 2 feet + shipping $35, and can get the 5/16" x 1/4" male barbs for about $2.50 then the 1/2" size for the 2 ends, couldn't be more than $4 each. Can borrow taps and bits from Pop. $70 dollars or round about and Pallnet guy on Hybridz wants $155 for a great looking fuel rail I think I could make without the fancy lines machined into it. Anybody ever done it? Is it harder than I think? I know I'd have to use that clear sealer instead of teflon tape. Edited October 21, 2011 by siteunseen add attachment Link to comment https://www.classiczcars.com/topic/41136-make-a-fuel-rail/ Share on other sites More sharing options...
240260280z Posted October 21, 2011 Share #2 Posted October 21, 2011 Pallnet is first class and saves the headache and risk of errors when learning on your first rail. Plan to drill and cut two. If you want to improve on the design, source extruded aluminum with two internal passages for send and return and integrate an fpr in one end. You can also use the stock rail, cut it and bubble flare the ends or braze barbs on the ends: It will look like this: Link to comment https://www.classiczcars.com/topic/41136-make-a-fuel-rail/#findComment-369802 Share on other sites More sharing options...
siteunseen Posted October 21, 2011 Author Share #3 Posted October 21, 2011 Pallnet is first class and saves the headache and risk of errors when learning on your first rail. Plan to drill and cut two.Cool. I'll have a spare. Link to comment https://www.classiczcars.com/topic/41136-make-a-fuel-rail/#findComment-369863 Share on other sites More sharing options...
laminator Posted November 18, 2011 Share #4 Posted November 18, 2011 A friend of mine found this site http://www.rossmachineracing.com/dash6.html Link to comment https://www.classiczcars.com/topic/41136-make-a-fuel-rail/#findComment-372057 Share on other sites More sharing options...
siteunseen Posted November 18, 2011 Author Share #5 Posted November 18, 2011 That's the same company I'm looking at on e-bay. They have "scratch & dent" for $5 a foot also. I think I'll listen to Blue's advice and buy the cheaper for a study guide and the good stuff for my finished fuel rail. Thanks for the heads up. Link to comment https://www.classiczcars.com/topic/41136-make-a-fuel-rail/#findComment-372082 Share on other sites More sharing options...
laminator Posted November 18, 2011 Share #6 Posted November 18, 2011 I was thinking order a 6 ft of dash 6 material. for my new rails. Link to comment https://www.classiczcars.com/topic/41136-make-a-fuel-rail/#findComment-372095 Share on other sites More sharing options...
siteunseen Posted November 18, 2011 Author Share #7 Posted November 18, 2011 (edited) Do it! I think with a drill press and some drill bits and thread taps it would be easy. Looks like 1/2" on the ends and 1/4" threads for the injectors and cold start. 5/16'' barbs. Thread 2 holes on the bottom for the mounts. I am thinking of mounting my Fuel Pressure Regulator somewhere around the heater hose in & out on the firewall and run the return line from the FPR straight down to the metal line back to the gas tank by the vacuum bottle. Shirley we can do it. Edited November 18, 2011 by siteunseen Link to comment https://www.classiczcars.com/topic/41136-make-a-fuel-rail/#findComment-372121 Share on other sites More sharing options...
laminator Posted November 19, 2011 Share #8 Posted November 19, 2011 For my Z is less complicated, because my Z gots megasquirt Link to comment https://www.classiczcars.com/topic/41136-make-a-fuel-rail/#findComment-372136 Share on other sites More sharing options...
siteunseen Posted November 19, 2011 Author Share #9 Posted November 19, 2011 I wish I could say that, less complicated. I hope it turns out like you want. "Megasquirt" that's a funny word. I'm going to read up on those. Link to comment https://www.classiczcars.com/topic/41136-make-a-fuel-rail/#findComment-372175 Share on other sites More sharing options...
siteunseen Posted November 20, 2011 Author Share #10 Posted November 20, 2011 (edited) Here's the fuel rail that looks better. http://www.azspeed-marine.com/furaex.html it's finned or milled. Whatever, but also read "Milling fins into any surface will increase the available surface area for heat to dissipate from. Increased air flow across the fins would keep the rail cooler." Edited November 20, 2011 by siteunseen Link to comment https://www.classiczcars.com/topic/41136-make-a-fuel-rail/#findComment-372220 Share on other sites More sharing options...
Willoughby Z Posted November 20, 2011 Share #11 Posted November 20, 2011 ... Shirley we can do it. Who's Shirley? 1 Link to comment https://www.classiczcars.com/topic/41136-make-a-fuel-rail/#findComment-372228 Share on other sites More sharing options...
Zed Head Posted November 20, 2011 Share #12 Posted November 20, 2011 Here's the fuel rail that looks better. http://www.azspeed-marine.com/furaex.html it's finned or milled. Whatever, but also read "Milling fins into any surface will increase the available surface area for heat to dissipate from. Increased air flow across the fins would keep the rail cooler."The fins are great for transferring heat from hot to cold. In the engine bay, hot is the engine and cold is the fuel rail. The fins will result in hotter fuel not colder.Just something to think about. Link to comment https://www.classiczcars.com/topic/41136-make-a-fuel-rail/#findComment-372245 Share on other sites More sharing options...
