I seem to have all connections made to the body harness and all electrics seem to work in the back:
- passenger door switch
- room lamp
- all tail lights/turn/rev/4way flashers (except brake light which I will chase down today)
- license lamp
- marker lights
- speaker
- power antenna
- defrost
- fuel sender
So I am wondering what the 3 unused wires in the body harness do?
One is red and seems to be a loner with a long-ago broken off connector
The other two (which seem to be paired) have the bullet connectors (one is black and the other is red or red with a black stripe..I forget exactly).
The only two single wire connectors that I connected to the body harness were a green (bullet) and also the one from the pass. door switch (blade).
https://www.classiczcars.com/topic/41152-3-orphan-wires-in-body-harness/
Thanks Steve,
It is a 71 240z. They are at the head of the harness that goes to the back of the car. This location is in the passenger kick panel area near the top door hinge.
Here is all the FSM shows (I added the red and the black and red paired):
  • Who's Online   1 Member, 0 Anonymous, 1,527 Guests (See full list)
