I am having issues with my FI relay connector, I have cleaned the connector used dielectric grease on it and I am still having issues. Does anyone have a good remedy for this? I understand that I could re-pin the entire connector, do you guys know a good place i can pick up some terminal inserts?
The pins can be removed from the connector blocks for cleaning and inspection. There is a tiny slot in the connector cavity at the back of each female connector where you push a very thin "something" into, to depress the sticking-out tang on the connector to free it. I use dental tools or a very small flat blade eye glass screwdriver. Once you get one out, the rest are a breeze once you see how it works.
Do them one at a time or make a careful drawing and label wires or you risk mixing things up.
I have a couple of spare FI relays too if the problem turns out to the relay. Let me know
  • Who's Online   2 Members, 0 Anonymous, 1,224 Guests (See full list)
