I am looking for any race brake pad manufacturer that makes racing brake pads for the Toyota 4 pistion brake caliper that goes with the "Stock Solid 240z' Rotor. I believe this caliper is from a 1979-1983 4x4 truck. It is not used with a vented rotor.
Any advice is greatly appreciated.
Greg
https://www.classiczcars.com/topic/41351-toyota-caliper-race-pads/
I read good reviews of these pads from "down under" 6 years ago and put a set on my Z. Had it on the track once and no fade but I was not pushing like you:
PBR Metal Masters
http://www.pbrperformance.com.au/performance.htm
Edited by Blue
I've got the PBR Metal Masters on my car. They are quite old so I'm not sure if they've changed them since I bought mine but I like them. They do tend to want to squeak every so often though. Not bad for dust. Decently easy on rotors.
Had the RS4 porterfield ones on my truck, really great pads. A fair amount of dust but not as bad as some I've had. Good initial bite and then as they heat up they grab even better. Could notice it on 70 mph stops at stoplights on the highway, I'd have to let off on the brake pressure as I could feel the friction increasing as it slowed.
Trevor
http://240z.me
