VWer picking up a 240z w/ frozen brakes... HELP
Hey, I work on lots of VWs and brakes are a snap. I'm getting a 240z for free (1973) and I was wondering how easy brakes are... are the rears drums? The car has been sitting for a few years in Oakland, CA and the rotors are rusted-frozen...
What's it gonna take to replace the rotors / drums. I have a lot of exp working on VWs (clutch jobs, brakes, susp, exhaust work etc... and am an engineer...)
Thanks!
The breaks on a 240 are not much differant than
a VW rabbit. To remove the rear drums that are
frozen/corroded on you may need some heat & a
hammer. Heat evenly around the drum face then
tap lightly and repeatedly all around the drum face
where you just heated. Should come off - mine did
that way. Congrats on the Z - Welcome to the club,
good times for all!
-Jeff
This might help there is product called PB Blaster , it is a great rust penitrater , apply it to the end of the axel on the drum,and let it soak. Then tap with a hammer an wooden block on the FRONT of the drum or out side , just tap all around and try to dislodge the drum , then do the same from the rear , or back side, being careful not to damage the fins . Be patience and it will rock loose.
  • Who's Online   2 Members, 0 Anonymous, 1,505 Guests (See full list)
