Under the rear of the car has reminded me that this next project is a doozy..
Firsty the previous guy cut the spare wheel well out to put a flat floor in it, which is a bit of checker plate bolted in and scrap metal tacked in place. so that will be getting ripped out and a wheel well welded back in.
next is it had R31 disk rear brackets welded on not too well, and from what i gather that path was not going to be easy nor legal, so i will be grinding it off and putting drums back on.
Then theres the diff. It has this wicked burnout sick drag car spec centre in it, which i will be replacing, but on a good note i was told it has 3:9s in it. Which i was told at datsport that if it does, their not easy to come across.
All i can see stamped on the crown wheel is 'H 3 9 X 1 1 J 7-3' any ideas? (Edit. just found its 39/11 = 3.54 ratio. ie stock ratio) another bull**** fact thrown in when i bought the car
Also has big fuel lines that were bent all dodgy down the car as it was going to have fuel pumps under the car for the RB20. So new fuel lines will be run.
Another good note is that it has nolathane kframe bushes, wishbone bushes, diff mustache bushes, new pedders shocks and low king springs!
FUN FUN
Edited by tez240k
So this is what im working with...
what was under the boot..
what they welded in place..
and some nice cut n shut work in the boot... not sure of the reasoning for this..
Then i noticed the rust repair in the rear quarters has been left untreated and theres real crispy bits of metal that probably still contains rust in the bottom so will grind it all back and see what needs doing.
  • Who's Online   2 Members, 0 Anonymous, 1,372 Guests (See full list)
