tez240k Posted April 28, 2013 Author Share #145 Posted April 28, 2013 (edited) Under the rear of the car has reminded me that this next project is a doozy.. Firsty the previous guy cut the spare wheel well out to put a flat floor in it, which is a bit of checker plate bolted in and scrap metal tacked in place. so that will be getting ripped out and a wheel well welded back in. next is it had R31 disk rear brackets welded on not too well, and from what i gather that path was not going to be easy nor legal, so i will be grinding it off and putting drums back on. Then theres the diff. It has this wicked burnout sick drag car spec centre in it, which i will be replacing, but on a good note i was told it has 3:9s in it. Which i was told at datsport that if it does, their not easy to come across. All i can see stamped on the crown wheel is 'H 3 9 X 1 1 J 7-3' any ideas? (Edit. just found its 39/11 = 3.54 ratio. ie stock ratio) another bull**** fact thrown in when i bought the car Also has big fuel lines that were bent all dodgy down the car as it was going to have fuel pumps under the car for the RB20. So new fuel lines will be run. Another good note is that it has nolathane kframe bushes, wishbone bushes, diff mustache bushes, new pedders shocks and low king springs! FUN FUN Edited April 28, 2013 by tez240k Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=13#findComment-421792 Share on other sites More sharing options...
uras1 Posted April 28, 2013 Share #146 Posted April 28, 2013 eerrrrrhhh, what do people think Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=13#findComment-421797 Share on other sites More sharing options...
tez240k Posted April 28, 2013 Author Share #147 Posted April 28, 2013 They think 'I heard you can put r31 brakes on it might wack some brackets on. Bit of rust in floor.. Hmm grinder will fix that! Weld some mounts to cross member, cut up the chassis to fit an intercooler. Bang. Race car. Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=13#findComment-421803 Share on other sites More sharing options...
uras1 Posted April 28, 2013 Share #148 Posted April 28, 2013 poor thing, at least your saving it from certain death Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=13#findComment-421805 Share on other sites More sharing options...
tez240k Posted April 29, 2013 Author Share #149 Posted April 29, 2013 So this is what im working with... what was under the boot.. what they welded in place.. and some nice cut n shut work in the boot... not sure of the reasoning for this.. Then i noticed the rust repair in the rear quarters has been left untreated and theres real crispy bits of metal that probably still contains rust in the bottom so will grind it all back and see what needs doing. Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=13#findComment-421873 Share on other sites More sharing options...
240k Style Posted April 29, 2013 Share #150 Posted April 29, 2013 Bugger! Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=13#findComment-421903 Share on other sites More sharing options...
Hoybo Posted April 29, 2013 Share #151 Posted April 29, 2013 When bogans get classics.. Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=13#findComment-421961 Share on other sites More sharing options...
uras1 Posted April 30, 2013 Share #152 Posted April 30, 2013 haha, be a good movie title Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=13#findComment-422016 Share on other sites More sharing options...
tez240k Posted May 2, 2013 Author Share #153 Posted May 2, 2013 Painted diff brace Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=13#findComment-422262 Share on other sites More sharing options...
240k Style Posted May 2, 2013 Share #154 Posted May 2, 2013 Nice! Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=13#findComment-422266 Share on other sites More sharing options...
uras1 Posted May 2, 2013 Share #155 Posted May 2, 2013 shiny and new Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=13#findComment-422268 Share on other sites More sharing options...
Adzmax Posted May 3, 2013 Share #156 Posted May 3, 2013 Looks good! Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=13#findComment-422354 Share on other sites More sharing options...
