PLZ818 Posted November 2, 2013 Share #181 Posted November 2, 2013 Looking at all those parts...... i have a certain hatred against you haha jks mate. If i may ask how much where the skyline badges? Also Blue GT = N/A Red GT = Turbo. Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=16#findComment-435124 Share on other sites More sharing options...
240k Style Posted November 2, 2013 Share #182 Posted November 2, 2013 hmmm you have a lot of dash faces....might need a practice one to strip for the aluminium panel Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=16#findComment-435155 Share on other sites More sharing options...
tez240k Posted November 4, 2013 Author Share #183 Posted November 4, 2013 (edited) Um I think the side skylines were about 80aud and rear one about 70. Off Yahoo japan. Yes I love my spares Edited November 4, 2013 by tez240k Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=16#findComment-435348 Share on other sites More sharing options...
tez240k Posted January 7, 2014 Author Share #184 Posted January 7, 2014 Well with some time off work thought I'd get stuck in. Removed drums off k frame I got from paddock car. Painted backing plate and ordered new protex brake cylinders and shoes off eBay. I've also started wire wheeling under the car as it's all surface rust and painting with killrust enamel. And finally took the grinder to the brilliantly welded in boot to cut out the 44 gallon drum lid out. Was hoping i sneezed so it'd fall out. Then To replace with new spare wheel well. Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=16#findComment-439160 Share on other sites More sharing options...
tez240k Posted January 15, 2014 Author Share #185 Posted January 15, 2014 found the wheel well i was using had rust in it, so i cut the whole bottom out and replaced it. ive seam sealed it, and will paint it. so got new brake shoes, and cylinders. started installing them and the pins, springs and retainers wernt looking great, so went to power brakes and... bang. new ones Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=16#findComment-439643 Share on other sites More sharing options...
uras1 Posted January 16, 2014 Share #186 Posted January 16, 2014 should stop well now Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=16#findComment-439751 Share on other sites More sharing options...
240k Style Posted January 17, 2014 Share #187 Posted January 17, 2014 Drum internal looks the goods man Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=16#findComment-439818 Share on other sites More sharing options...
tez240k Posted January 18, 2014 Author Share #188 Posted January 18, 2014 Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=16#findComment-439855 Share on other sites More sharing options...
tez240k Posted January 19, 2014 Author Share #189 Posted January 19, 2014 Cut the welded on bracket for disk conversion which was quite tricky. All that's left now is hook up handbrake and brake line and that's passanger side done. Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=16#findComment-439919 Share on other sites More sharing options...
240k Style Posted January 21, 2014 Share #190 Posted January 21, 2014 i've got a few of the finned drums sets lying around if youd like to go that way Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=16#findComment-440036 Share on other sites More sharing options...
Red Rocket Posted March 17, 2014 Share #191 Posted March 17, 2014 Hi Terry,I just read through the entire build thread you have here, man what a journey over a couple of years and you still have a way to go.Really admire your determination and passion for your K project.Good luck with the rest of the build, I'm sure everyone can't wait to see it in the flesh!!H. Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=16#findComment-443624 Share on other sites More sharing options...
Red Rocket Posted March 17, 2014 Share #192 Posted March 17, 2014 Under the rear of the car has reminded me that this next project is a doozy..Firsty the previous guy cut the spare wheel well out to put a flat floor in it, which is a bit of checker plate bolted in and scrap metal tacked in place. so that will be getting ripped out and a wheel well welded back in.next is it had R31 disk rear brackets welded on not too well, and from what i gather that path was not going to be easy nor legal, so i will be grinding it off and putting drums back on.Then theres the diff. It has this wicked burnout sick drag car spec centre in it, which i will be replacing, but on a good note i was told it has 3:9s in it. Which i was told at datsport that if it does, their not easy to come across.All i can see stamped on the crown wheel is 'H 3 9 X 1 1 J 7-3' any ideas? (Edit. just found its 39/11 = 3.54 ratio. ie stock ratio) another bull**** fact thrown in when i bought the carAlso has big fuel lines that were bent all dodgy down the car as it was going to have fuel pumps under the car for the RB20. So new fuel lines will be run.Another good note is that it has nolathane kframe bushes, wishbone bushes, diff mustache bushes, new pedders shocks and low king springs!FUN FUNHi Terry,I know you've well and truly sorted your diff woes out by now, but it got me wondering, and please anybody chime in with your knowledge or opinions.....We have a 78 280zx 2+2 5 speed that has a disc braked diff. Has anybody used one of these units to upgrade a 240k sedan or coupe? They seem to be very similar just looking at it under the car but I haven't measured anything.H. Link to comment https://www.classiczcars.com/topic/41457-terrys-project-240k/?page=16#findComment-443626 Share on other sites More sharing options...
