5thhorsemann Posted December 4, 2011 Share #1 Posted December 4, 2011 I want to coat some areas of the belly with POR-15 before the government starts dumping carcinogens all over the roads this winter. I don't want to over buy the POR, it is pricey. My question; what is the coverage, in Sq. Ft. for a quart of this stuff, or how much did it take to do one drivers side floor pan within and without. (inside and outside) Link to comment https://www.classiczcars.com/topic/41552-por-15-coverage/ Share on other sites More sharing options...
cajunz Posted December 4, 2011 Share #2 Posted December 4, 2011 (edited) I've done my floor pans inside and about 3/4 of the underside of the care with a quart and had some left over. It's pretty thin and goes a long way. Great stuff but as usual, its all in following the prep instructions. A quart will be more than enough and if you seal up the can, it can be stored in the fridge and last a pretty good while. Edited December 4, 2011 by cajunz Link to comment https://www.classiczcars.com/topic/41552-por-15-coverage/#findComment-373624 Share on other sites More sharing options...
madkaw Posted December 4, 2011 Share #3 Posted December 4, 2011 1/2 pint would do one side of the floor- it goes a long way. The hardest part is not to put it on too heavy. Try and put it on as thin as you can- it flows out really well Link to comment https://www.classiczcars.com/topic/41552-por-15-coverage/#findComment-373627 Share on other sites More sharing options...
5thhorsemann Posted December 5, 2011 Author Share #4 Posted December 5, 2011 Thanks guys. Link to comment https://www.classiczcars.com/topic/41552-por-15-coverage/#findComment-373705 Share on other sites More sharing options...
tlorber Posted December 5, 2011 Share #5 Posted December 5, 2011 I think the age of the paint matters as well. I have bought a can that was thick and did not flow, and I have bought one that was thinner and laid down much better. In any case, you are better with the smaller cans. A one gallon would dry up on you before you could use the entire can and you are not supposed to thin POR 15. Link to comment https://www.classiczcars.com/topic/41552-por-15-coverage/#findComment-373722 Share on other sites More sharing options...
5thhorsemann Posted December 5, 2011 Author Share #6 Posted December 5, 2011 I hope you guys are right, I bought a Qt. and I hope it will do the pans, sounds like it should be enough. Link to comment https://www.classiczcars.com/topic/41552-por-15-coverage/#findComment-373752 Share on other sites More sharing options...
