I used the K&N pump from MSA. It's been working just fine for the last year. It's not as quiet as MSA makes it sound, but once the car is started I can't hear it.
Here's the link to the pump;
http://www.thezstore.com/page/TZS/PROD/classic17a09/11-3078
  • 8 months later...
The Airtex 8012S is rated 5-9psi at 30gph.... shouldn't we use Airtex 8016S which is rated 2.5psi - 4.5psi at 30gph ?
Just curious ?    I am looking to add one to supplement my Mechanical pump as backup...
Many thanks.....
I've been using the Holley Premium Red Electric fuel pump.  It's a great pump, but, a bit too loud for my taste.
I want something a little less noisy.  I'm running triple Mikuni's, so I'll need something compatible.  Not sure if this one will be any less noisy but I'm strongly considering the Nissan Nismo pump (if I can even find one).  Zcardepot.com has them listed, but, out of stock.
The K&N from MSA you listed above looks interesting..  Airtex is also a possibility...  I do like the simple design of the Airtex.  It doesn't stand out as aftermarket.
