Mine were very difficult too. I ended up using a block of wood to protect the hub and beating it hard with a large mallet. When that didn't work on one then I use one of my favourite tools a BFS (Big F#$king Screwdriver) and positioned it between the disc and hub to use as a pry bar, without damaging the hub and only digging into the rotors. Then you work your way around the disc and hub slowly prying it out a bit each time it will eventually come out.
https://www.classiczcars.com/topic/41752-new-front-brakes/#findComment-375528
  • Who's Online   1 Member, 0 Anonymous, 639 Guests (See full list)
