How do you remove the doors safety feature?
I took apart my door and lubed everything up because it was hard to open and the handle needed to be tightened down.
Before I did this, I could lock my doors from the outside and then shut them and it would stay locked (both sides).
Now after lubing everything, my door locks will pop open when I shut the door while locked.
My key only works to "unlock" my door, and will not lock it.
How can I remove this feature because it obviously was working just fine without it before lube.
When you re-tightened everything to "where it was" you didn't.
Look at the linkage from the outside key lock to the latch mechanism, it may be that you didn't extend the "nut/screw" that connects the 2 far enough for the key lock to properly push down on the latch.
You can test all this by removing the door panel (sorry) and then tightening that nut/screw so that after you've "latched" the door (while keeping it open) you can then use the key to lock and observe the latch mechanism. It's a pretty straight forward process.
FWIW
E
FWIW
E
The only thing I tightened was the slack before opening the door handle so that it would not wiggle, and on the passenger side all I did was spray lube on all the joints and it did it.
I found out that you can bypass the feature by holding up on your door handle as you shut the door, so I'm perfectly fine with everything.
Edited by Milenko2121
