Well i have bad news, I got the motor in the car and running today but i cant seem to bring the timing to the 5 degree mark.
Take a look at these and look where the tang points relative to the 6mm threaded hole:
Looks like you may be a tooth off on the spindle to drive gear making it too retarded (ccw).
Edited by Blue
This is what I'm referring to supporting the cam tensioner. The attached file is a couple of pages from How to Rebuild Your Nissan & Datsun OHC Engine.
The wooden block is what your talking about in the rebuild guide?
Yeah i may be off one tooth. Damn!!!! so does that mean i have to unbolt the oil pump and restab the spindle?
  • 4 years later...
Somebody on this site has described a way to adjust the quill from the top.  I think it might have been CO.  Used some sort of rubber band assembly to hold the quill up from below, then just pushed it down against the rubber with a pair of long-nose pliers off of the gear and turned it to and fro util it came up in the right spot.
The short answer is - re-insert and check, with the timing pointer on zero, and the #1 piston at TDC.  Best to get everything set correctly, even the cam sprocket.
You could also logic it out, knowing that the distributor turns counterclockwise.
  • Who's Online   1 Member, 0 Anonymous, 1,503 Guests (See full list)
