Site Updates this Weekend ×
240z engine & compartment paint colors
I was searching for paint colors for the engine and engine compartment and came across a list like this but it was for an early Z and a few years old. Does this list work for a 1973 240z?
Please make changes as needed or add to the list.
Note: it was mentioned about a lot of overspray that left items looking blue.
Block: Datsun Engine Blue
Oil Pan: Black; Semi-Gloss - gloss
Crank Pulley- Engine Blue
Smog/ Air Pump Pulley - Engine Blue
Smog/ Air Pump Casing: Natural
Smog/ Air Pump Rear Plate: Semi gloss Black
Bolts and fittings were all cad plated /(depending on location might be painted engine blue)
Timing Cover - Natural Aluminum
Water Pump: Natural
Alternator Casing - Natural Aluminum
Alternator fan clutch - Natural aluminum
Alternator Pulley - Semi Gloss Black
Alternator Fan - Gold Cad Plated
Alternator adjusting arm – Engine Blue
Securing nut and washer in the Alt center - gold cad
Cam Cover: Natural
Head: Natural Aluminum
Oil Pump: Natural
Distributor: Natural
Air Box: Orange (My original one is blue)
Fuel Rail: Cad Plated
Carb Linkage: Cad Plated
Bell housing cover plate or 'end plate" - Silver zinc plated
Motor Mounting Brackets: Black
Intake Manifold: Natural
Exhaust Manifold: Natural
Alternator/Smog Pump Adjusting Arms - Engine Blue
Misc. Water Pipes: Cad Plated
Cooling Fan: Off-White or Antique White
Cooling Fan Clutch: Natural
Cooling Fan Pulley: Cad Plated
Thermostat housing & Water pipes/heater hose fittings - Natural Aluminum
U-shaped water tube located behind engine part of the carb heating system. – Cad plated
Your list looks right to me. The metal bladed cooling fan was on the very early cars & painted off-white /antique white. They were replaced with the white plastic fan when the metal fans were reportedly flying apart. Your 73 should have the plastic fan.
Bonzi Lon
  • 5 months later...
Just thought I would add to this. I have an untouched 1970 240z with original paint. There are parts that are turquoise (what is referred as Nissan Blue above) on mine that differed from the list include the following:
- The rear block water pipe
- 3 way water pipe connector including bolt head to block
- hose clamps to pipe connector. Not the one to the heater hose
- hose clamps either end of hose from connector to water inlet housing
- not sure about The head water pipe T fitting
The splash pan and the fuel filter bracket are also black.
Edited by Webmanic70
  • Who's Online   0 Members, 0 Anonymous, 992 Guests (See full list)
