cozye Posted January 16, 2012 Share #13 Posted January 16, 2012 Watch good for leaks. Mine was put in without sealant and it leaked around the bottom corners bad. The water would work around the glass in the bottom corners and the center. The installer fixed it however. Link to comment https://www.classiczcars.com/topic/41876-77-280z-front-window-trim-installation/?page=2#findComment-377659 Share on other sites More sharing options...
Casey_z Posted January 16, 2012 Share #14 Posted January 16, 2012 They installed the little corner pieces after the window was in.They were done in less than an hour and charged $230.00.The second picture was the installer putting in one of the corners.Hope this helps.Casey Link to comment https://www.classiczcars.com/topic/41876-77-280z-front-window-trim-installation/?page=2#findComment-377669 Share on other sites More sharing options...
