hey guys. ive ripped my L24 out my 240K, and im looking at freshening it up a bit.
ive got a set of early 240Z SU carbs to put on it, that im looking at getting restored. anyone had experience with getting them cleaned and re-coated?
What are peoples opinions on what I should do to the motor thats worthwhile.
So far im thinking: valve seat grind, rings, bearings, gaskets, bore hone. (Will be doing most the work myself)
-been told timing chains on these motors are worth changing?
-mechanical fuel pump? change to electric?
-was looking at the 280z dizzy, but im not keen on losing my tacho?
-bigger alternator worth while?
-etc
I have no experience with these motors so any help is appreciated!
cheers
Terry
https://www.classiczcars.com/topic/41976-rebuilding-l24-need-advice/
The L24 is a great motor and are tough as nails. There is a ton of info on this site and others as far as what people have done to these motors----and stuff that really didn't need to be done too! Your question is very general and you might want to do more searching and come up with a plan that the members here can help you refine. If you are doing the work yourself, than the time invested searching with be priceless.
