What is this? (connection on engine)
Is it a P90 head or a P90A? The P90 heads are sought after because they don't have the hydraulic rocker arm pivots.
With a good light, and maybe a mirror, you might be able to see the flat top of the piston through a spark plug hole, if you find a cylinder with its piston at TDC.
