Need pics of triple mikuni linkage-especially from firewall
Like the title says, I need some visual help on putting together my linkage from my PHH 40 Mikunis to the firewall of my 71-240. I have been studying pics on this site and others but not having much luck seeing what i want to see.
I am running a Mikuni shorty manifold. The kit I bought had an extra bellcrank with a ball on it for the rod and ball linkage. Presently I am thinking of cutting my SU rod and mounting this bellcrank on it and doing something like that.(I will post a pic when this is done), but like to see what others have come up with. So if you have any close-ups of the firewall set-up that would be great.
My advise is to do away with the old linkage in it's entirety from the pedal to the carbs..........you'll be glad you did. Check out my garage for info. Just smooth acceleration from stop to go. No more jerking and dead spots in the linkage cause it's not there.
The "stay holder" bolts to the cover of the last carb and holds the "terminal holder". You should be able to make one pretty easy using something like this: http://www.jegs.com/i/Mr-Gasket/720/3811G/10002/-1?parentProductId=763730
I have attached a pic of my old setup so you can see where everything bolts together.
Lokar Throttle Cable - I would strongly recommend this modificaiton to anybody looking to remove the old linkage. Just attach to the gas pedal - through the fire wall - to the carb using the support - pretty straight forward install - no linkage slack at all - no linkage binding period. I'll never go back to the old linkage (I did keep the throttle linkage setup and the SU's, and they are in storage).
Let me know if I can explain anything in more detail.
Steve-
Be sure to review this thread - good stuff and not as much money as you think. I got my support bracket from Wolf Creek Racing.
http://www.classiczcars.com/forums/showthread.php?30584-Accelerator-linkage-fix-questions
  • Who's Online   1 Member, 0 Anonymous, 1,472 Guests (See full list)
