  • 2 months later...
Found a reaction disc.....thanks PJOE. I removed the two nuts holding the brake master cylinder to the master vac.....then pulled the master cylinder back 4 to 5 inches. I shined a light in the master vac and sure enough, the reaction disc was absent. I epoxied the disc to the adjustable plunger and pushed it back in. It's raining, so I haven't test drove her yet, but there's absolutely no question that the disc is what made the brakes work a little funny. Hope this helps someone else.
https://www.classiczcars.com/topic/42098-reaction-disc/#findComment-387942
